Wood's better
Evening all,
I hope you can help?
I have taken up an unsuitable floor and re laid using tongue and groove 22 mm plywood, glued joints and glued and screwed to the joists. I want to overlay with 6 mm Hardibacker
A question if I may?
Is it advisable to prime the plywood first and if so with which primer and dilution (I understand that the adhesive is only to fill voids, however, think I would like the best possible adhesion!)
Many thanks in advance
Richard.
Richard.
