Discuss Problem gap at ceiling in the British & UK Tiling Forum area at TilersForums.com.
L
ljmountain
I am tiling my bathroom, it is my first wall tiling project (have done a couple of floors). When deciding the layout I had to make a decision about where to have a narrow cut (I did the tile height story stick), for better or worse I decided to have this at the ceiling (I would have placed this at the floor level with hindsight - I have learnt a lot from this forum in the last week!). The cuts are going to be between 20mm and 50mm high (tile is 200mm high x 250mm wide), I believe the rule is not to make cuts less than 20% so I am breaking rule by having cuts of 20mm. My wife has suggested we don't do the cuts and use coving, I was considering this but this forum has made me think it will look like I am hiding something. I am 95% complete with the tiling and only have this last row of cuts to complete, the rest of the bathroom looks fantastic and I don't want to ruin it. I think I have three options (if there are more please let me know!):
1) Use coving\cornice
2) Accept cuts of 20-50mm
3) Rip out the last row of tiles and put a second mosaic border in place, this will then finish with 140mm - 170mm cuts at the ceiling level (I already have a 50mm mosaic border at 1000mm).
Thanks in advanced.
tommyzooom
1,083
Ireland
A second border sounds the best idea, or do your cuts at the ceiling, see what it looks like when its grouted etc, and if you dont like it , then put up coving. If the tiles are white with white grout, they probably won't be noticable
Some rooms, when you have to think of the roof, floor, bath height, shower tray, window sill, door head, window head etc, a narrow cut somewhere is sometimes unavoidable
Time's Ran Out
I'd only consider the coving option if its used in the rest of the house.
A mosaic border or the small uneven cut will both take the eye up to the top of the walls.
Another viewpoint would be to reduce the ceiling height and level it at the same time with either a new boarded plaster ceiling or batons and plastic panels.
Hindsight is a great asset!
H
hillhead
Also you said somewhere had to have to small cut ie ceiling or floor?So you had a full tile on floor i take it?A cut there would have give you a better cut at ceiling too.It's all in the laying out all the time.It's one the main decisions us tilers have to make on every job early on.Ceiling lowered is a good idea but i'd go for coving myself, coving in same colour as the architrive etc?
Gall.B
Good poin about setting out often the first give away as to wither a pro did a room or not, the problem with a small cut round the top as opposed to a fullish tile is it highlights how far out your ceiling is which it probably is dipping down at the corners etc.
cladding is an option tho more work and more expensive and you probably will end up putting some sort of cornice round it.
Reply to Problem gap at ceiling in the British & UK Tiling Forum area at TilersForums.com
Hi all! Might be an easy question for the pros! I have a 12x14 tile that I am going to...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
