H
hitthenorth
Hello - first post here but first thanks for all the great info I've gained as a lurking guest
Having successfully tiled our ensuite a few years back I'm now tackling the bathroom.
I've put two coats of neat Bal APD on the plaster skim as per the instructions. I thought it had gone OK but when putting some pipework through for the shower I accidentally removed some of the plaster skim and in doing so found the primer had formed a latex like coating on the surface that can be peeled back like removing pva from your fingers or peeling skin after sunburn.
It sounds a lot like the issue here (had to change the url because I can't post links as a newbie :-( ) h t t p : //www.tilersforums.com/guest-area/54799-peeling-primer-skim-bal-apd.html
I thought it was confined to just that wall but sticking a bit of sticky tape on the other walls pulls a latex like layer off those too so I suspect it wouldn't hold the tiles.
So my questions are:
Seems knocking the plaster off was probably fortunate before I'd put the tiles on!
Thanks in advance.
- I rubbed the walls with a wire brush as they are fairly smooth but maybe I should have sanded or something as well - is that likely the reason?
- What should the primed walls look/feel like if it has taken properly?
Thanks in advance.
