mikedavey
Hi.
I'm tiling around a window in a bathroom with 250 x 200 tiles. Got a tricky situation that i'll try to explain. When setting out the tiles (250mm going vertically) and i put the tiles on the inside of the window sill on the LHS & RHS, the tiles are about 10mm too narrow to actually fit. I thought well as it's only 1 tile high to fit on the LHS & the RHS so i'll put a slither against the window & it won't really be noticed...BUT doing this the grout line won't look right against the tile i lay flat in the window sill.............I hope this makes sense....:huh2: :huh2:
It will look odd you agree??
If you can understand what i am trying to say could someone reccommend what to do.....
