L
leaking
I'm having problems with a mosaic tiled ledge (12.5cm wide and 8cm up from the bath) in my bathroom. It is on the wall side of the bath and the taps come out of it.
I tiled onto 12mm exterior ply, no primer, over a wooden structure I built to support it. I used grandfix supergrip and granfix flexible limestone grout. I have just taken the tiles up because they were coming loose and there were cracks in the grout. Obviously I've done something wrong!
I think there must be some tiny movement in the shelf structure, but also the wet is getting right through to the ply where it is under the shower - its gone black! The tiles on the wall are fine.
This is my second attempt to fix this problem - I would really value some good advice. Thanks.
Tamara
Tamara
