Discuss Problems Cleaning Non Slip Tiles In A Changing Room in the Tile Cleaning and Restoration Forum area at TilersForums.com.
Whooshman
Looking for some advice. We recently tiled 4 changing rooms which are not cleaning up anywhere near as well as expected.
We used HG Cement, mortar & efflorescence remover but it hasn't made much difference.
The tiles are Canuk Abete purchased from Solus. The grout was Mapei Anthracite.
Any help on our next move would appreciated.
blades
I will write what I do before I combine non-slip tiles with dark Mapei grout, I try to discourage the customer (if he choosed the dark), customer never understands what is this and it's not their job to understand, but it's my job to do the best - in that case not to let it happen. Good luck with this
ps. I use a product called Megarens from Mapei to remove excessive grout, in your case pure Megarens-do not mix with water. Let it act for a couple of minutes, rub well and then clean well with water.
Whooshman
Thanks for the info, I'll look into the product
Reply to Problems Cleaning Non Slip Tiles In A Changing Room in the Tile Cleaning and Restoration Forum area at TilersForums.com
Hi all. After living in my property for over 7 years I've recently discovered the type of tile...
Hello I kindly ask a professional opinion for a huge problem i have I am selling special...
Thanks for taking your time to read through this and really appreciate the support! So me and...
Hi, apologies for the repeat post, I hadn't seen this forum when I posted yesterday, but I think...
Greetings All, appreciate the expertise existing in this forum. I am a home remodeler, not a...
5K
Tile Restoration Trending Topics
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
