Discuss Procedure Enquiry in the British & UK Tiling Forum area at TilersForums.com.
U
Unregistered
WAS OUT TODAY WITH A TIME SERVED TILER OF 25 YEARS TO GAIN VALUABLE EXPERIENCE. AS A NEWBIE (DONE NETT COURSE IN JAN)I WAS OVER THE MOON AT BEING INVITED OUT WITH THIS GUY INTO THE REAL WORLD OF TILING!
QUITE SHOCKED ACTUALLY WITH REGARDS TO NO USE OF PRIMER, 6MM PLY NAILED ON FLOORS ETC. BUT MY MAIN QUESTION IS ABOUT ADHESIVE BED. HE WAS USING DISPERSION ADDY WITH LARGE FORMAT CERAMIC WALL TILES APPLIED WITH A HALF CIRCLE FLOOR TROWEL. TRIED TO ASK POLITELY BOUT CURING DEPTH OF DISPERSION ADDY (4mm I THINK) BUT WAS TOLD THAT WAS JUST COURSE NONSENSE. THINK I WILL PLOD ALONG ON MY OWN TO START WITH. MIGHT B A BIT SOWER BUT LEAST IT WILL BE BY THE BOOK.
MARK
GazTech
MARK
No primer on plywood, nailed not screwed (nails ok if annualar ring nails)...thats a no no. Large format tile with dispersion adhesive,also a no no.... .a 10mm notched trowel is ok for large format on walls. I would keep well away, only time before a job goes wrong and you will also be held to blame..He obviously has no respect for tile courses...get out of there before you pick up bad habits......Gaz :thumbsup:
Reply to Procedure Enquiry in the British & UK Tiling Forum area at TilersForums.com
Procedure Enquiry
Tags
usa
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
