H
Homza
Apologize if this had been discussed before.
This is a quote from the US version of the Ditra installation handbook. Are your installation instructions the same? I have heard that in Europe use of polymer modified thinsets to bond tile to Ditra is approved.
I know from experience that a quality unmodified does provide a good bond, but at times I would prefer using a modified thinset. Schluter does allow rapid setting modified to be used but I prefer normal setting material for most jobs. Maybe you have different products available than we do?
Schluter USA Ditra Handbook said:"QUESTION Can ceramic tile, including porcelain tile, be set on Schluter®
-DITRA with unmodified thin-set mortar? ANSWER YES. In fact, we recommend it. Here's why:
Portland cement-based unmodified thin-set mortars are dependent on the presence of moisture for hydration in order to gain strength. Since Schluter®-DITRA is impervious, it does not deprive the mortar of its moisture. This allows the cement to properly hydrate, resulting in a strong, dense bond coat. In fact, after the mortar has reached final set (usually within 24 hours), unmodified thin-set mortars achieve higher strengths when cured in continually moist conditions.
QUESTION
Can ceramic tile, including porcelain tile, be set on Schluter® -DITRA with latex-modified thin-set mortar?
ANSWER
We DON’T recommend it. Here's why:
Latex-modified mortars must air dry for the polymers to coalesce and form a hard film in order to gain strength. When sandwiched between two impervious materials such as Schluter®-DITRA and ceramic tile, including porcelain tile, drying takes place very slowly through the open joints in the tile covering. [According to the TCA Handbook for Ceramic Tile Installation, this drying period can fluctuate from 14 days to over 60 days, depending on the geographic location, the climatic conditions, and whether the installation is interior or exterior]. Therefore, extended cure times would be required before grouting if using modified thin-set mortars between DITRA and ceramic tile, including porcelain tile. If extended cure times were not observed, the results could be unpredictable. This is even more important to consider in exterior applications that are exposed to rain as there is the additional concern of latex leaching."
