• Thread starter MiguelPlumbelo
  • Start date
  • Replies 0
  • Views 67
Discuss Pushfit fitting/pipe ok to rub against one another? Discussion Thread in the Plumbing Advice area at TilersForums.com.
Hi
I've been swapping rads in my house and during one rad swap I used the original notches on the joist to run the new flow and return pipes. In one notch both the flow and return touch and might get pressed against each other when the chipboard goes back down.
Should I open up the notch or reroute the return (left valve pipe)? Or is it ok they touch together?
I've attached photos to illustrate, last photo is a general picture of the whole setup
Thanks in advance
Pushfit fitting/pipe ok to rub against one another? for the original thread on Plumbers Forums
Reply to Pushfit fitting/pipe ok to rub against one another? Discussion Thread in the Plumbing Advice area at TilersForums.com
TF Group Please Join
Plumbing Advice
Tags
None
