Discuss Putting down hardi six mil boards down on floor for travertine tiles in the Canada Tile Advice area at TilersForums.com.
I
Ian
Re: Putting down hardi six mil boards down on floor for travertine til
Can i ask why you'd need Ditra in this situation? I'm still new to using membranes, and can't see the benefit of using it on top of the Hardie!?!
It will help to absorb any lateral movement that is associated with wooden/heated substrates.
beanz
Berkshire
I understand what the membrane is for, just not sure it's needed in this situation, as two layers of flexible adhesive should (I would have thought) be enough to take up the lateral movement. Up until recently, i'd always overboarded with 12mm Ply, and tiled directly onto this.. I've changed my method recently, as i can see that Ply could shrink enough to be a problem, but saying that not had a fail yet luckily..
I
Ian
It is a very belt and braces approach, I'm usually happy with just cement board if the floor is not heated, but if the combination is, wooden substrate/heated/soft stone, I'd always opt for the membrane, doesn't take much to crack trav/limestone/marble.
Reply to Putting down hardi six mil boards down on floor for travertine tiles in the Canada Tile Advice area at TilersForums.com
Hi all! So I got to a job yesterday downstairs wetroom floor with mains underfloor heating...
hello Folks, its a tiny area. 1.8 m2. Joists are solid 3 inch wide. Area is upstairs close to...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
