Guest viewing is limited
Discuss Putting spacer between first tile and kitchen work top to allow for movement of work top in the Canada Tile Advice area at TilersForums.com.
james hailwood
353
Bolton
Kitchen fitter on a job I'm gonna be on Monday said to put a spacer between the first row of tiles and the wooden work top for Silicon. I've never seen this before in 11 years. does any one do this? seems bit extreme, I'd usually just start off the work top and Silicon at end. it's for the movements of the work top but seemed bit ott.
Time's Ran Out
2mm is wide now :(
disagree TJ
On the contrary - a 2mm joint would necessitate a 4mm Silicon joint and that is absolutely perfect, especially colour matched.
But how many turn out 8mm and more till all you notice is the joint.
Never understand why people go for 'real wood' worktops. So unhygienic and when you get there to start tiling they are always going to seal them after you've finished!
Dumbo
Don't really understand your first paragraph. Maybe I'm stupid .
Time's Ran Out
I think it's Pension Day, so is mind might be on other things. ;)
Where I can spend it! But only every other week.
Don't really understand your first paragraph. .
If you leave a 2mm spacer gap as suggested by the member for Essex, then in my opinion it allows a 1mm covering to tile and worktops = 4mm of Silicon visible.
Tile Shop
tis true.....
Sorry...... I really am that bored!
Reply to Putting spacer between first tile and kitchen work top to allow for movement of work top in the Canada Tile Advice area at TilersForums.com
gamer1
Hi all Having a bit of a mare; after having my last shower installation botched (but thankfully...
7K
Perfect Tiling
Hi all, new signup here beginning first tiling job. We've got a conservatory room at the back...
I'm doing a second floor condo kitchen, 6' by 9' of tile area. The surface is gypsumite...
Hi all, I was hoping I could get a little advice. Currently doing a bit of tiling in the...
Dumbo
Bolton
Business Name
Hailwood Tiling Contractors
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
