Discuss PVA plasterboard or not? in the UK Tiling Forum area at TilersForums.com.
doug boardley
this is sbr
obobsmith
Hi I have just read the instructions and it reads: Prime porous surfaces with 1 part unibond PVA diluted with 5 parts water and allow to dry. Seal with solvent based primer.
DO NOT put PVA on the board, erase the word from your mind as far as tiling is concerned, shame on the addy manufacturer for suggesting this should be done.:yikes::yikes:
dock
Very strange for a manufacturer to advocate the use of a PVA primer indeed a primer at all with a ready mixed adhesive. PVA is water sensitive and will reconstitute as the water contained within the adhesive hits it. This can also affect bond development at the adhesive/substrate interface leading to the formation of a much weaker bond than should be the case.
Normally when tiling with ready mixed adhesives its a good idea NOT to prime. Most decent ready mixed contain water retaining agents to control suction on porous surfaces so if you prime the drying time of the adhesive will be significantly extended because the polymer cannot start the cross linking process until water/moisture is lost from the adhesive. Where primimg is required i.e. particularly dusty plaster use a dilute acrylic or styrene butadiene rubber (sbr)
Reply to PVA plasterboard or not? in the UK Tiling Forum area at TilersForums.com
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
Hello everyone, My names Fraser I have been in the motor trade for 17 years, after falling out...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
