Guest viewing is limited
Discuss Quartz 600 x 600mm installation - Advice pls in the UK Tiling Forum area at TilersForums.com.
Richard Edwards
I've read a couple of posts re quartz and the issues of delamination and curling up at the edges and it sounds dreadful. I will be going to look at a job soon 150m 2 of 600x600 Quartz 10mm thick.
I do not know what kind of screed we have until I see it - however its heated with hot water system and it will be a premier quality job if the construction co doing the work are true to form.
Basically what adhesive is recommmend for this Quartz tile assuming a heated screed - either standard cement/sand screed or an anhydrite screed - If it Anhydrite maybe if Ajax sees this post he could comment
Many thanks
Richard
Ajax123
1,213
Lincolnshire
Ufortuntely I am not prepared to make a positive recomendation on this one, regardless of the screed type in all honesty, other than to say I don't beleive, based on research over the last few months and first hand knowledge of 3 incidents of 10mm resin quartz tiles curling over underfloor heating, that these tiles are suitable for this application. Sounds harsh I know but it is heart breaking to see good people seriously disappointed and financially battered because the tiles have curled and delaminated.
For what it is worth I would not use these tiles on a heated screed. B&Q say theirs are not suiable
Richard Edwards
Thank you for the replies to date - If anyone else has any experience of laying Quartz on a water heated screed and have used special / specific adhesive / grout - please let me know. This job is 150m2 and it would keep me occupied for a bit - That said I do not want a bag full if issues.
Ajax - The ones that you are aware of curling up at the edges etc - were they on electric or water heated systems - ?
Thanks in advance
Ajax123
1,213
Lincolnshire
Thanks in advance
All on wet heated screeds. All the tiles were from the same source. Company based in the North East. All of the issues I have been aware of are from the same tile outlet.
Reply to Quartz 600 x 600mm installation - Advice pls in the UK Tiling Forum area at TilersForums.com
Be the Best with BAL! The importance of correct training should never be underestimated. As the...
8K
