Discuss Quartz 600x300 wall tiles in the Australia Tiling Forum area at TilersForums.com.
Dave UK
Hi,
Can anyone please tell me if Quartz starlight Ivory tiles 600x300 are safe for the walls. My builder will be using untracolour 299 limestone alupak grout and fast setting flexible quartz tile adhesive white 2 part. As informed by the tile store we will also prime the tiles.[h=1][/h]These tiles will go in my kitchen between the top and bottom kitchen units on newley plastered, skimmed walls. The only reason I am asking this is because of the weight of each tile and as I have children I am concerned they may fall off and cause an injury.
Any answers will be much appriciated.
In a quick reply before I hit the hay, then yes, the application seems fine although I assume you mean your builder will prime the walls, not the tile (unless you mean seal the tiles). Do you not have a tiler ? Or does your builder have a tiler ? Watch out for whoever is fixing them to use the correct method (A trowel with teeth) of fixing and not dotndabbing the tiles onto the wall (5 blobs of adhesive of the tile and squished into place)
Stef
These tiles will be fine for a splash.
The only problem you are going to encounter is your electric sockets as your going to have to cut them into the middle of a tile or get them to land on a grout line or you start with a half tile from the worktop.
As said you should have about 480mm between worktop & wall unit, cut the tiles in to suit.
Andy Allen
1,318
Gloucester
Your wrong im right. ..lol
Joking aside....good point ...should think the op has at least 4/5 m2 of tiling and will probably only have 1 full tile and just over half of another tile stacked. .at least its not in a bathroom if it did fail...but would make sure the skim plaster is well fixed.
Stef
Agreed Andy, if it was in a different room then yeah he would be taking a risk.
I fixed red quartz as a splash in a kitchen behind the cooker & came off them with porc 600x300s but all sockets were moved to suit.
Looked nice with minimal grout lines.
Dave UK
Many thanks to everyone for all the info, my next thought is to cut the tile down to a 300x300 for the walls. How easy are Quartz midnight tiles to cut. If they are cut then they have less chance of falling off. I assume a water cooled tile saw with a diamond tile blade will do the job, but are they easy to cut?
Reply to Quartz 600x300 wall tiles in the Australia Tiling Forum area at TilersForums.com
Hi. My daughter is having a walk in shower fitted by builders. I am concerned because most of...
Notts_Rob66
N
Hello folks, I just finished installing my base and wall units and now need to tile the kitchen...
gonna use granfix cfta slow white and wet the back of the tile with acrlic primer mix ..these...
J Sid
Hi all, I am just looking for some advice regarding my shower room. I have a newish house (2.5...
22K
Joseph Kover
Hi, I would like to get some opinions on using marble stone on walls. I was going to go with...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
