Discuss Quartz and under floor heating in the Canada Tile Advice area at TilersForums.com.
F
Flintstone
Alright chaps,
Had a call about a job which I have to quote,
Not got the full info until tonight but what I have is, 35 sq m, multi room, quartz. Also there's ufh wants fitting first, they apparently have all the materials supplied by tile giant. I'm getting more info tonight. New build onto concrete.
Question is, I don't recall ever fitting quartz before so I know about the adhesive but does this require a decoupler, and where should I be with the pricing for laying based on I would be in at £30 per m for porcelain unless they were really large
Q
Qwerty
Ive done a few quartz jobs, and one was over elec ufh (only 100w). Those tiles were from Tile Giant too. I used Tilemaster rapid Setaflex with their flexible additive over Ditra. Been absolutely fine.
I can't help but feel that some failures are due to cranking heat up on 150w mats (& water ufh) too soon and/ or using incorrect adhesives. Don't get me wrong, some quartz are totally unacceptable for ufh which is why I specced lower wattage with the tile giant tiles.
F
Flintstone
Some food for thought here guys, I'll ask them to email me over all the bumf from tile giant and deffinately ask them for some confirmation of suitability. So if it is suitable, would tilemaster crack may suffice? Also, it's a new build, concrete floor, what's the situation with drying times with concrete when considering what there proposing
One Day
I never understand that? If it's great at vapour management, where is the moisture in the screed going to go?
Been on their courses? Seriously good if you've not been!
Schlüter®-DITRA 25 | Function | Schlüter-Systems - http://www.schluter.co.uk/ditra-25.aspx
"c) Equalisation of vapour pressure
The interconnected air channels between the cavities on the underside of the Schlüter®-DITRA 25 matting remain open. This allows moisture in the substrate to evaporate, therefore neutralising vapour pressure."
Reply to Quartz and under floor heating in the Canada Tile Advice area at TilersForums.com
I’m continuing to lift tiles on my dot & dabbed kitchen floor over retofit ufh. i thought I’d...
gamer1
I am sure someone will know a good practice solution. We started a wetroom last year and then...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
