Discuss Quartz problem? in the Australia Tiling Forum area at TilersForums.com.
I fitted pink quartz(pre sealed)from Topps tiles months ago,
the customer wanted black grout but I was instructed to check on tiles for staining before grouting.
i checked a few with the black grout under the bath where it was getting covered and I wiped off immediately after grouting but left the tiles stained.
i told the customer about this and he said to seal it twice with advice thru Topps but it didn't make a difference.
the customer still wanted me to use black on it.
anyway I did and have tried different things on it from acetone to bleach but still not coming off.
the tiles were £100/m so trying to source something that will strip them back.
the customer has accepted it's their fault but I'm looking for advice.
Concrete guy
Chemically, quartz is extremely resistant.
Suggestions:-
1/ Phone the manufacturer of the grout and ask them what chemical will dissolve their grout.
2/ If number 1 doesn't produce any results try hydrogen peroxide, but understand this may bleach the black grout in the joints so try it on an inconspicuous area first. Do a google search for "Hydrogen Peroxide Poultice for Marble" to understand more about what this is and how it works.
3/ Lithofin used to produce a product called "Stain Away". I'm not sure if they still sell it. It was such a caustic chemical I think it was withdrawn. Anyhow - if you can find some we used to use it to solve problems like yours along with red wine stains on white quartz. (Chances are it's probably hydrogen peroxide based)
Reply to Quartz problem? in the Australia Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
Work Done Epoxy grout was installed by the Grouting company on the tiles on the external balcony...
  • Sticky
Tilers Forums on FB
