Discuss Quartz tile cutting and fitting in the Canada Tile Advice area at TilersForums.com.
jamieh2608
hello im new on here I have a question.
I am planning on fixing some quartz 10mm thick wall tiles around my fireplace. the fire is electric and not in use as we have central heating.
the tilesi am using are 300mm x 300mm x 10mm
I have measured up and will need only 7 tiles.
will the wall be ok to hold this and what is the best way to cut them and does anybody recommend a particular adhesive
thanks in advance for any suggestions
thanks
jamieh2608
Wet cut only really , Are they Quartz or Resin based?
What is the wall constructed from now. Either way you should be ok in this situation weight wise but you will need the correct adhesive.
hi the wall is made of plasterboard with a skim over it.
they are resin based I think not entirely sure ill have a check tonight when I get back.
what adhesive is best as im guessing standard tile adhesive wont be no good
Reply to Quartz tile cutting and fitting in the Canada Tile Advice area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hello, I am hoping I may be able to get some advice. 2 years ago we had a new kitchen fitted and...
    Votes: 5 4.1%
    Votes: 11 9.1%
    Votes: 7 5.8%
    Votes: 33 27.3%
    Votes: 16 13.2%
    Votes: 31 25.6%
    Votes: 3 2.5%
    Votes: 2 1.7%
    Votes: 19 15.7%
    Votes: 18 14.9%
    Votes: 13 10.7%
    Votes: 6 5.0%
    Votes: 3 2.5%
    Votes: 2 1.7%
