monkeyhanger
Ok, i've been posting quite a bit on here to find out what I need to do, here's what I think I need to do, based on other threads which have given advice - any suggestions to steer me down the right path if i've misinterpreted anything before I buy all the gear?
I'm tiling Starlight Black Quartz from Tiles HQ: 300mm x 300mm x 10mm tiles in a shower recess - 3 walls at 800mm wide x 2100mm tall (above shower tray) and on a wall in the bathroom up to 1250mm tall, with a few cut outs for plumbing (Sink and Toilet).
I'm going to reboard the areas to tile with aquaboard, using the ceramic coated screws to fix it to my studs. 3mm gap between the boards, with Silicon up the gap and tape across the corners?
The advised tile adhesive is Mapei Keraquick. Would you advise to mix normally with water, or use latex plus as a substitute to the water?
If I use latex plus, will this significantly change the time the workable time and/or drying out time for the adhesive? If it does, how long should I leave fixed tiles before grouting?
Which size notched trowel would you use to apply adhesive to the aquaboard walls?
Butter the tiles with adhesive too?
Should the backs of the tiles need a clean (and left to dry) before fixing?
Use Ultracolour Anthracite to grout, or could this become patchy when wetted with the shower in use?
Grout gaps as small as possible on bevelled edge tiles - eg 2mm grouted spaces?
Silicon the vertical corners of the shower instead of grouting?
Using the 365drill 7 piece kit for my cut outs, and a new plasplugs diamond wheel cutter.
Thanks in advance for confirming or readvising on the above.
