L
leony
Hi,
One of our clients that we supplied have got a problem with quartz tiles. They have done the installation themselves and now they are saying some tiles are popping out:
The method they have used if I try to explain briefly:
- Tiling was done using 10mm notched trowel
- Tiles were skimmed back with more adhesive to solid back over underfloor heating cables
- Customer claims underfloor heating was never turned on after our warning.
- The sunlight beams through patio doors and the area gets warm.
- The warped tiles (like banana shape) pops up where the sun hits but also where the sun does not hit
- Cooker might give heat from bottom and this will be insulated (builder says)
- 20mm expansion gap were left all around the room
- The adhesive been used is single part flexible adhesive (not two part)
- The substrate is not clear but from the information seems like plywood.
- We do not know how many mm is the grout gap
The question they are asking, why would these tiles get warped like banana?
Also if you advise what else we can ask to get more info.
Any help is appreciated as currently as usual they blame the tiles.
