Discuss Question on setting out in the Canada Tile Advice area at TilersForums.com.
I
ian158
Ok I am laying 300x600 high polished porcelin around a bath..the bath width is 760mm...usual length is 1700mm so only going to bath width and length..where would you start on the 760 wall..use a full tile leaving a cut of 158ish..she's undecided on brick bond yet but if not I'm not sure a cut of 158ish will look good in the corner? What would you do ?
Time's Ran Out
I would do whole tile on the short end and cut into the corner (160 cut) and then whole tile center of centre on the long wall (550mm cut)....then the "wrap" around will look like whole tile!
If I understand correctly.
All the best
Lee
If they are stacked this will mean more tiles and wastage. If broken bond he may be able to use some of the off cuts.
But I'd do the same after making sure there were enough tiles before I started.
Protilers
I did a quick scribble in the pub.....earlier today.......I tried to upload it off my phone........but the upload button was off screen....oh well......
does this suit?
Protilers
I cant get the photo off my phone where on the right hand side there is 80mm against 550 (nice) but then there is 160mm cut against 250mm cut ....(kinda half tile)......
- - - Updated - - -
Is that to scale Lee? :lol:
yep.........I work in mm......its 50-1 Bri!...get your scale rule out and check!
hehehheeheeee
Protilers
Not keen on some of your lines - did you just use an eye line or did you have access to a laser level ?
Also think that the 710 and 330 mm cuts are uneven to follow round, so I'd suggest it's back to the pub or drawing board!
what do you mean BACK?...hehhheheheeeee
I am already here with the PAD....where are you?.......I have a pint on the bar waiting!
Protilers
hahahhaaaa... you would never notice it......but I did have an option 2......630mm and 410mm!...........hehehheheheeee....
I would go with option one......if it was 3 sides of a standard bath.....personally!.....I think it will look best!......but that is mearly an opinion......and we all have one of them!
nite nite John!
Leeeeeeeeeee:thumbsup:
Reply to Question on setting out in the Canada Tile Advice area at TilersForums.com
So I have a bathroom to do in 100 x 200 metros. Lucky me. Taps are on long side of bath next to...
J Sid
Hi, Running a small bathroom job for a customer. Customer really wants to use a particular...
10K
It's been a while since my last tiling job. We finished a kitchen renovation some time ago and...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
