There are many blogs out there showing a table of maximum weight certain substrate - for example:
...and they all say 20kg for gypsum-based plaster - so I'll assume we are talking about products such as multinish in most cases
So I have been looking into this as I wasnt sure if this refers to:
you see where this is going....
The plaster will have a different weight limits in each case!
Here is what I have found out.
Mapei say that you need to use a plaster primer to stop the adhesive sulphates reacting with the plaster and making the tiles come away from the plaster. See here:
So I thought this was why the 20 kg limit.
But then I found something on British Gypsums website top of page 3:
...which says:
"You can apply tiles up to 20kg per m2 directly to Thistle
finishing plasters, except where the system includes a
bonding agent. As the total weight of tiles and plaster
applied over a bonding agent is limited to 20kg per m2,
consider tiling directly to the background instead."
So, is the 20 kg limit because of the PVA used by the plasterer?
Does anyone have experience with large format porcelain on multifinish on a block wall?
https://www.**********.co.uk/knowledge-base/tiling-background-weight-limits
- fresh skim on new plasterboard
- reskim + PVA on previously skimmed plasterboard
- reskim + PVA on previously skimmed block wall
- fresh skim on Thistle Hardwall on block wall
- fresh skim on sand and cement undercoat on block wall
Primer G 1kg | Tile Mountain
Prepare your surfaces for tiling with Primer G 1kg. Essential for a professional finish. Simplify your projects – order now for efficient surface preparation!
www.tilemountain.co.uk
...which says:
