Discuss Questions of all Questions... deflection ! in the British & UK Tiling Forum area at TilersForums.com.
2020Tiling
was wondering at wot point of a quotation you would determine there was to much bounce in a floor ? i mean how do i no if i need to quote for taken up floors etc ? is a tiny bit bounce acceptable ? as the addy is flexi ?or is there something you can put down on a floor with slight bounce instead of ripping up floors etc ? the reason iam asking is that ive been to price up a lot of floor jobs , but starting to wonder about how much bounce (if any ) is acceptable ? :8:
mikethetile
its difficult to explain, there is a bs standard on this but measuring deflection is difficult, I go to the middle of the floor and bounce on the balls of my feet if the if I can feel movement the floor has deflection, if I cant the floor has minimal deflection
the problem with tiling suspended wood floors is the joists are designed to deflect slightly to absorb shocks and noise and with a tiling system the floor needs to be rigid or cracks may appear across the floor, I have also seen the grout break up from the constant movement
its best to overboard anyway
doug boardley
excellent question Terry:thumbsup:, I feel that if it's a marginal point and the customer really doesn't want the floor ripping up, I can do it with S2 flexi adhesive due to it's enhanced flex properties. This, as a two part adhesive, is more expensive than a S1 type adhesive though. I must stress though, I do recommend replacing floors that have any deflection.
Ajax123
1,213
Lincolnshire
guess it depends what causes the deflection. Live Loading,\Dead Loading,\Soft body impact, hard body impact, creep etc etc.
Standard timber joists are designed I beleive to allow no more than L/300 where L is the length of the span and the result should be less than 12mm to meet NHBC standards. When we design timber floors to take Gyvlon Screeds in the soundbar system and other timber separating floors we allow for a design deflection of just 5mm. These are tiled regularly without any issues.
doug boardley
have we got an interpreter available please:lol:
Reply to Questions of all Questions... deflection ! in the British & UK Tiling Forum area at TilersForums.com
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
6K
As I was in the middle of the monotonous task of laying subway tile all the way up a bathroom...
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
