N
N!ck
Evening,
Quick intro; Ive been lurking on the forum for a few weeks in prep for a job I am doing on my kitchen tomorrow. Im an engineer by trade but have a couple of tiling projects under my belt ( full bathroom including tiled bath panel, and my mams kitchen). Having gained a lot of info from here I am planning on doing the best job I can tomorrow - 600x600mm porcelain onto a screed/slc floor - and there lies my first problem.
In preparation I have bought some Primer G to use before using keraquick adhesive. Do I need the Primer G? Having looked online on the data sheet http://www.mapei.com/public/COM/products/532_primer g_gb.pdf it makes no mention of using on screed in the application section. However in the Keraquick data sheet http://www.mapei.com/public/GB/products/103_Keraquick_UK.PDF it says anhydrite screeds must be dry etc and treated with primer G.
The second Q is about setting out; if I center the first tile in the doorway I will end up with approx a 120mm cut along a wall to the right. If I center 2 tiles (so the grout is in the center of the doorway) It obviously gives me a much larger cut but I am unsure if that will look unprofessional as you walk through the door. What would a pro do?
My final Q is also about setting out - hopefully the 3 quick diagrams explain my thoughts. Basically the width of X+Y+Z is grater than 1209mm (2x600mm + 3x3mm spacers). Also Y is where the oven is and is not central (there is a bigger gap to the left - X ). I am just after peoples opinions really, particularly myself and the mrs currently dissagree!
Thanks for your time
Nick
Nick
