Guest viewing is limited
Discuss Quick one on Hardibacker in the Canada Tile Advice area at TilersForums.com.
Hopefully a quick one. I’m laying 6mm hardibacker direct on floorboards, without wanting to screw through a waterpipe does anyone know roughly how thick floorboards will be ( I am not in a position to lift them between now and when the job starts). I’m hoping I can buy 16mm turbo screws and they will do the job. I’m spreading BAL pourable 1 as the adhesive to fill any voids.
Thanks.
Waluigi
Some houses I’ve worked in have 15mm T&G. Average I work In is 18mm for T&G.
Usually it’s only above 18mm in the older floorboards.
25’s are the standard size screw used.
I’ve never worked in a house where I was unable to check the floorboard depth. There is always a way. Straight to the airing cupboard. Often loose boards there and always lots of pipes in holes.
Reply to Quick one on Hardibacker in the Canada Tile Advice area at TilersForums.com
Hi all, I'm redoing my bathroom that I did 15 odd years ago. Before it was tiled with 20x20...
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Hi All, It's my first post here. I'm currently working on a wetroom in my flat and would love to...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
Essex
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
