Grace'sDad
Just wondered what you'd do?
I'm faced with painted plasterboard walls (dot n dabbed). The paint (2 layers) has been well keyed and doesn't pull off at all with the duck-tape test.
There are so many stray pipes and cables behind the boards that I am loathe to drill, plug and screw backer boards up. (I think the walls were altered by rogue traders).
I need to fix 450 x 300 travertine, using BAL SPF.
I want to score up the paint using my hardibacker knife, right through to plaster, prime with BAL Bond SBR and tile away.
Would anyone else do this? I don't think I'd do this with BIG travertine but my metal detector was lit up like a xmas tree on these walls. I cut out a few holes and there were leccy cables strung at 45 degrees and microbore heating pipes everywhere!
watyoofink???
watyoofink???
