Discuss quote help please in the British & UK Tiling Forum area at TilersForums.com.
Grace'sDad
Can I have some help please - need to quote 12sqm concrete (flat and ready) floor. Fixing 30x30 (ish) slate.
Any ideas what you would charge? Labour only.
I know it needs a good sealing before fixing and again before grouting. A good clean up and re-seal finally.
It's uncalibrated but not too differing in thickness 12-15mm.
Thanks chaps!
TilingLogistics
I would want about £350 to do that, as you will need to sort out tiles, thick, medium, thin before laying, and the final coat of sealing would have to be done the following day when grout and tiles are dry. There is a bit more work than just laying ceramic tiles. Good luck :thumbsup:
I would want at least that as well don't forget it's all got to washed, sorted and wetcut!!! Why can't they be sealed the same day?
Kev
GazTech
I've seen the slate I am to use and it's pretty good. Not 100% square but it barely deviates in thickness. I suspect the worst thing wil be the cleaning before sealing and grouting. Oh well - here we go......!
It's a walk in the park for a man of your capabilities Mark.....Gaz
theyomper
Just wash them down as you go, then before sealing wash the whole floor down, let it dry and give it a good seal. When I do slate it's the only time that I will bite the bullet and use my grouting gun as it's a lot easier to clean afterwards. After grouting give a good wash down and another coat of seal........job done. Have fun.
Reply to quote help please in the British & UK Tiling Forum area at TilersForums.com
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
Pro help please... i have a large outside area 6msq approximately...ive just had a concrete...
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
quote help please
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
