Quote required - East Barnet
Status
Not open for further replies.
theodotcom
Hi
Can anyone give me a rough quote on a bathroom floor that needs to be tiled, the floor area to be tiled is approx 2m x 2m, tiles and adhesive need to be removed (which i can do if need be) and the current flooring for the tiles is floorboards.
Re: Quote required
It is hard to give an estimate without actually seeing the job. From your previous post it appears that you have had problems with a previous job.
We would need more details to give you an indication. What type and size of tiles are you laying and are the bathroom chinaware going to be removed or are they to be cut around? Where are you based is always useful as well.
Re: Quote required
thanks for the reply, the tiles are normal ceramic tiles from b&q, i think the size is 330x330mm and 8mm thick, the sink is with a unit and does not need to be moved, the toilet currently has tiles going underneath it, so may need to be moved although not too fussed if it is cut around.
Also have some tiles cut down to act as a skirting.
Re: Quote required
Thanks for the extra info. I am sure some guys closer to your location will respond later today when they are back from work.
Re: Quote required
:thumbsup:You get a better look and its easier for the tiler if you remove the wc.A rough guide on pricing would be around £125-£150 as the floor will need to be ply'd out and flexi adhesive and flexi grout used.Hope this helps.You can also use a 2 part flexi but i personally would ply it out.Oh and the door will probably need trimmed down.:thumbsup:
Re: Quote required
and whats the state of the floorboards like,if there are any loose ones they will have to be repaired,so that the ply would be screwed/nailed to a solid base
i'm a tiler based in Finchley Central i could give you a price if you wanted ....my name is Chris give us a call i'll pop around and give you a free estimate and some advice if you like.my number is 07731862173.....
Status
Status
theodotcom,
chrismcmahon888,
theodotcom,
chrismcmahon888,
