Discuss Quoting for a large area with Wedi Board in the British & UK Tiling Forum area at TilersForums.com.
tay1974
Just been to the health club to look at the job before I quote. They want me to quote them for two jobs. This is for two changing/shower areas with a total sq meter of 105 sq m.
The first quote they want is to remove all the old grout and re-grout and change any damaged tiles. Basically the old grout has gone yellow and they therefore want it looks nice and new again. I have suggested they use Bal Microban grount.
The second job is to re-tile the complete changing rooms including the floor tiles.
As I stated before, they advise me that the background is Wedi and therefore, I guess I will need to either remove the old Wedi board and replace with new or is it possible to just tank over the old Wedi board and re-tile over the top.
Also I have never removed old grout, is this an easy task or difficult and time consuming?
Paul
tile55
removing grout from tiles and regrouting without damagin the tiles can be a nightmare. It is time consuming and hard work.
The only way you will be able to realistically tell if you need to remove the wedi board aswel as the tiles is to do a spot check. ie try and remove a small section of tiles first and see how easy, or hard they are to remove, this is where the use of the Fein tool comes into its own.
L
Leatherface
Hi, removing grout from such a large area will be extremely time consuming and soul destroying, even with a Fein and diamond grout remover.
Removing tiles from Wedi will undoubtably destroy the Wedi.
You are setting yourself up for a fall if you quote for anything else than - remove tiles, replace wedi & re-tile.
They are obviously trying to do it cheap - beware ! Quote to do job right or walk away, could cost you dear !!!
Even if you decided to go down the re-grout route I very much doubt that you could give them a quote that would accurately account for your time spent !
Reply to Quoting for a large area with Wedi Board in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
