Discuss radiator pipes cutting in the British & UK Tiling Forum area at TilersForums.com.
sc24
yes, scribe the u shape, then run the wet saw blade up either side, then you should be able to snap the piece off with a pair of pinchers, reduce the small piece by the diameter of the pipe, then place the cut piece at the back of the pipe after you fit the tile making sure its flush with the tile, then grout the cut lines
Reply to radiator pipes cutting in the British & UK Tiling Forum area at TilersForums.com
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Hi everybody, I am about to lay my patio, 60x60cm porcelain tiles. I have just checked on where...
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Hello All, First post in this forum so forgive me if this has already been posted before. From...
AHTiling
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
