Discuss Radiator Removal in the British & UK Tiling Forum area at TilersForums.com.
TilingLogistics
Having read a few threads in the past regarding removal & re-installing of radiators before tiling, I am considering drafting a step-by-step guide inc. pics, for other members.
Just want to see are there enough members needing this info, to warrant the effort ?
Go for it!!! All help gratefully received! There will always be someone reading who finds it useful:thumbsup:
Kev
sibs
And make sure you screw the valve fully down.... some TRV's only go down to a frost setting in which case may not fully close the water off. I think you'd probably get a device that closes it fully from a plumbers merchant.
The one I recently took off I unscrewed the valve and put a thick rubber washer over the pin and screwed the valve back on again so as to make sure the pin was fully down before I took the radiator off.
Sorry if this complicates things... perhaps you could include an explaination as to how a trv works... It just screws down onto a pin in the fitting that controls or stops the flow of water. Great idea taz :thumbsup:
jamesy07
ok lads been having computer problems and could not post on the forum anyway,
if you go on to youtube and type in radtubeclamp there is a 9 min video on how to remove a radiator using these rad clamps ideal for tilers i think
google rad clamps and you will find there is plenty about will make your job easier
ps. ok gaz fixed now
Reply to Radiator Removal in the British & UK Tiling Forum area at TilersForums.com
Hi everybody, I've come up with a new way that I'd like the forum to work. I've built a quick...
Hello, first post, asking about career change and possible entry route into the industry. I know...
Radiator Removal
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
