Abstract tiling
hi done a few jobs lately where the customer has bought mapei rapid set grout find it not very clever to work with just wondered if any1 else has had this problem,cheers .:mad2:
Discuss rapid setting grout in the British & UK Tiling Forum area at TilersForums.com.
what seems to be the problem?
i do know when i started changing from bal i found the bucket life different and mixing felt odd but after a few bags you get used to it
bal tends to go off a bit slower,i use mapei and toppfix nowadays and the toppfix stuff can go off even quicker,just mix smaller amounts until you get used to it
Can't say I have had that problem with Ultracolor Plus!hi i have had this prob with mapie their grout has its own method forget how you grout normally the grout always sinks on floors so always go over it twice then you need to let it nearly set b4 washing you should charge more for using mapie as it always takes longer and is harder to get a nice finish
I copy that!
Mapei is one of the easiest grouts to use and you don't need to go over it twice at all?!
On floors your should have a solid bed, so there's nowhere for the grout to sink-to!
If your grout is sinking, you haven't put enough in, or you haven't fixed the tiles properly to the floor.
Reply to rapid setting grout in the British & UK Tiling Forum area at TilersForums.com
