Discuss Recommend a primer for tiling plastered / painted wall? in the British & UK Tiling Forum area at TilersForums.com.
siremastimus
I was looking to tile the area inbetween my worktop and kitchen units. It was plastered around a year ago and at the time had mist coats applied before a final coat of Dulux Soft Sheen - can this be tiled on top of as the upstand doesnt really allow for the extra depth backer boards would need? Tried the tape test and the paint stayed on the wall but I am guessing it would be best to use a primer still on the walls - if so can an expert out there recommend the best primer for this requirement? Thanks
PS Tiles are 400mm x 100mm x 7mm Ceramic if this matters,
Ajax123
1,213
Lincolnshire
primer wont assist the tiles sticking to the paint. you need first to ensure that the paint is well adhered to the wall. if it is then this can act as the primer. i would rub it down with a sander first and vaccuum it before though.
Ajax123
1,213
Lincolnshire
take the corner of a paint scraper to it and see if it flakes off the wall. if not it is well adered. as its a splashback my personal opinion as its a "DIY" job i would use a tubbed addy from the likes of wickes or b&q......... i shall now await the pro tilers backlash.
Ajax123
1,213
Lincolnshire
reason i would go tubbed is because it is acrylic dispersion and will stick more effectively to paint than it would to screed or plasterboard although i am open to correction. problem with paint i guess is its lack of porosity which would prevent to some extent the hydration products of cement embedding in the paints surface. generally paint (emulsion) is generally acrylic dispersed as well
Ajax123
1,213
Lincolnshire
prime if using tubbed, cementuous dont prime, that stuff will stick anything to anything. I personally prime everything. habit ! Its holding no serious weight so you will be fine. DIY job so you will be fine !!
i take issue with this. tubbed addy is generally self priming. cementitious will not stick to "anything" for a start it wont stick to gypsum..... sorry to be picky .... no offence
Reply to Recommend a primer for tiling plastered / painted wall? in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
Hello, I'm having trouble finding any decent stockists locally. I've got a Topps very near, plus...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
