Rosewood
Hi,
We have been in our house a few years but noticed as soon as we moved in that the tiles were loose, with grout cracking. Over the years we've had to replace tiles that crack. We now want to relay the entire floor with porcelain tiles.
We have a suspended wooden floor and as far as i can tell there is 18mm Ply screwed into the joists with the tiles laid on that. I believe there is a dry screed between the joists.
Previously when we've lifted the tiles they were not stuck down at all, with the adhesive stuck to the floor but not the tile. I'm not sure why this happened but this has happened throughout the whole ground floor.
We did get the hall re-laid a couple of years ago and the tiler had to remove all the adhesive from the ply floor with an angle grinder (v messy!). He then laid another layer of ply (not sure what thickness but probably 12-18mm) and then laid the tiles. This floor has been rock solid and these tiles look great.
My concern with doing this again in our (large) kitchen diner, is that this room is only just warm enough in the winter here in Scotland as we have a lot of heat loss (big double glazed windows) and if we lay another thick layer of ply I do not think we'll have enough heat transmission into the room.
So after that long spiel, my question is how would you best prepare the floor before tiling to maximise rigidity but also maximise heat transmission? Would it be ok to lay tiles directly onto the cleaned up ply (unlikely this will be totally smooth due to old adhesive) or would you lay another layer, and for that layer would you use ply or something like Hardiebacker? Also would be great if you can recommend adhesive and grout?
