Discuss Remove old wall tiles on 45mm adhesive in the UK Tiling Forum area at TilersForums.com.
bickyz
Hi my shower area has 15 years old tiles laid on 45mm thick cement based adhesive. These are 200mm x 250mm ceramic tiles.
I am looking to remove these tiles; Can someone please adivice me how to remove these or which tools to hire/use.
In the past I have used tile chisel/hammer to remove my kitchen old ceramic wall tiles which was laid on about 8/10mm adhesive But this shower ones are really thick.
Any help would be much appreciated, thank you.
Robb o
Hello Bickyz
I would use a SDS drill that allows you to use hammer only and a wide flat chisel.
I have a Bosch GB Professional that I use for this type of work,less arm ache than a kango or sds Max.
You might need to start off with a grinder and hammer and bolster to get 1 or 2 tiles off once you have done that try and get the chisel behind the tiles and level with wall.
Try to keep your chisel sharp or get a few and pay the re-sharpening charge.
Also if you can, to keep dust to a min get a pasting brush and a bucket of water and keep wetting adhesive as you chisel it off.
Hope this helps all the best with it.
Rob
Reply to Remove old wall tiles on 45mm adhesive in the UK Tiling Forum area at TilersForums.com
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
