DazJWood
I have fitted Hardiebacker boards and then Homelux matting to the stud wall in my shower cubicle area.
I have tiled over this using Mapei Proflexible Cement Based adhesive and travertine tiles.
All I have left to do now is the cuts above the shower tray. On the row above this I have one tile on the end that I have managed to incorrectly fit unlevel. The farthest end sits below the tile above by around 3mm.
Now this area is where the shower screen will be fitted so it will be pretty much hidden and disguised by the screen and I can squirt an extra bit of silicon where the screen meets the tile.
However because I know it isn't right I am trying to decide whether it would be worth trying to remove the tile and refit.
I am concerned though that it will not be the easiest to remove and also I do not want to damage any surrounding tiles. I wouldn't fancy taking a hammer and chisel to the tile as this would surely damage the surrounding adhesive and tiles.
Are there any tricks to removing a travertine tile careful so as not to damage substrate and surrounding tiles? (I'm not worried about ruining the tile because I can easily cut another).
Or should I just leave the tile as is. I'm sure it would only be me that would notice it anyway.
Thanks,
Daz
Thanks,
Daz
