je72
Hello all, this is my 1st post!
I'm a fairly inexperienced handyman, mainly because I've always lived in new builds and moved before any serious maintenance required doing. But I am looking after a house for my friends who are abroad. they have a 3 storey town house (newish build) with a shower on the 3rd floor. To cut a long story short the shower was leaking and as it was lined with plasterboard it had become plasetered with mildew (can you get ill breathing that stuff in btw?) I've removed the old tiles, 1/3 of it fell off after I removed the enclosure, 1/3 needed a gentle tap and the last 3rd needed sever brute force!
I now want to reline the walls so that this problem does not happen again, I am planning to use aquaboard or something similar. My question is, the plasterboard that is damaged the most is glued (dot & dabbed) directly to the concrete wall. How do I get this off with the minimum amount of fuss? Also what is the best way to "join" the new aquaboard to the plasterboard?
On the other wall (corner shower) the plasterboard is pinned to partition wall, and despite my best efforts following the guidline on here, I've still ended up with some sizeable holes, would it be best to chop that out also or just to board over it? I have a feeling it will be the 1st more diffficult method, but would appreciate any advce.
Cheers :smilewinkgrin:
