Discuss Removing paint from plasterboard before tiling in the Canada Tile Advice area at TilersForums.com.
Hi guys,
I cannot find a decent/fully applicable answer to this anywhere! Please help!
Substrate is painted plaster board. It was painted 2 years or so ago by the house builders, trade white, so is all very sound.
Tiles are 300x600 so I’m not happy with just scoring the paint to get a key. (Done this with metro tiles for splash backs etc in the past cos smaller tile).
I don’t think I can remove the plaster board because the whole wall isn’t being done and it seems a bit extreme. So I believe my only option is to remove the paint.
What’s the quickest / least messy way to do this ?? I’ve not really quoted much time for stripping the paint ☹️
Steamer and scraper?
Orbital Sander? If so what grit
Any other suggestions?
Thanks in advance!
Tile Shop
Best way is to buy cheap tubbed adhesive
Spread on the wall leave it 15/20 mins ,
Then scrap off,it will bring all the paint with it .
Slightly messy but if you scrape into a bucket or tub it's the best way.
Tried that for the first time before xmas, on a plaster wall. Worked a treat and something very therapeutic about doing it. Very satisfying indeed.......... or is it just me? :)
On one
Unfortunately ready mixed adhesive will not work on a drylined ie plasterboarded wall(it will work on a plastered wall),it will just dampen and damage the paper faced plasterboard before releasing the paint.
PVA-ing the wall and then skimming it with finish plaster would be my option
Reply to Removing paint from plasterboard before tiling in the Canada Tile Advice area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
Nottingham
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
