Discuss Removing plaster from internal wall to re-board in the Canada Tile Advice area at TilersForums.com.
L
lasors
Hello all,
I'm redoing the bathroom and will be using quite a large tile (400x300) on all walls. Two internal walls are plastered and are nowhere near flat, so to save me some pain later on I think it's best it comes off to be boarded to give me a nice flat surface to tile on and extra strength for the heavy tiles.
It's the original walls of a 1950s council house, timber studs with ash block/brick in between it seems. I was planning on using an SDS drill with cranked chisel and taking off all plaster down to the studs and attaching boards to these, probably with adhesive to level and mechanical fixings after.
Does this method sound ok? I'm worried about possible damage to the wall, particularly the plaster on the other side. Should I be? The wall isn't particularly thick.
Overboarding is not an option as space really is that tight given the desired furniture going in.
Thanks for any advice.
martin1c
633
Cheshire
Sounds ok to me. You might not need the SDS drill as a lot of the time houses of that age have plaster that is fairly blown anyway so a shovel behind the plaster can work. You could also consider a steamer if you have one as these will often blow the plaster too which is a lot more delicate if you're worried about the plaster on the other side of the wall.
John Benton
1,138
Leeds
It could be sand/cement as it was built in the 50's, some of the blocks in internal walls could be 50-75mm thick. Might be worth checking out, an sds could cuse more damage than good.
Yeah be very careful and check wall thickness prior to using SDS drill and also if you were thinking of chasing shower pipes into wall. You could end up with a hole in the next room as a plumber I used to work with found out to his cost.
Reply to Removing plaster from internal wall to re-board in the Canada Tile Advice area at TilersForums.com
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
Hello, Just about to embark on an extension and the first job is to move the bathroom into what...
Afternoon everyone, just after a bit of advice on preparing some walls for ceramic, possibly...
Hi all, I'm redoing my bathroom that I did 15 odd years ago. Before it was tiled with 20x20...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
