Removing Silicon sealant from aluminium shower screen
cornish_crofter
Hi
Have used a profile to Silicon between an aluminium shower screen and the tiled wall that it is attached onto to give the job a clean look. Unfortunately I managed to smear some Silicon onto the aluminium.
I want to remove the excess whilst keeping the seal.
Does anyone have any ideas as to what I could use please? I've tried the stanley blade but this can scratch the aluminium. Rubbing it is partially successful but it gets ingraned, despite having let it dry off for 24 hours.
Hi
Mask all the good Silicon around the offending area. Apply Aqua Mix Sealing & Coating Remover and allow it to dwell for 10 minutes. Wipe it off! Hey Presto:thumbsup:
Kev
Guys
Thanks a million!
I did the masking tape trick yesterday using some Silicon remover that I'd forgotten that I had. It's quite powerful stuff so I was worried about getting it on the Silicon that I wanted to keep.
However the masking tape did the trick and I was able to clean it back to the seal I wanted to keep using a clean damp sponge.
Afterwards I just dried the area then removed the tape then cleaned the whole area to remove any residual Silicon remover.
Many thanks for those pointers.
cornish_crofter,
cornish_crofter,
cornish_crofter,
cornish_crofter,
