Spud
while working in germany 15 years ago the german tilers i worked with had a good method of repairng cracked screeds they would follow the crack with a 4inch angle grinder and cut out the fault line , then across this they would cut stitch cuts every 6-8 inchs ,they then took steel screws and placed them into the cuts across the original fault line ,this was then filled with epoxy resin and left to cure. the floors were then tiled, i have used this method many times and found it to be very useful cracks were not transfered into the tile installation. have any other of you tilers used this method to repair cracks in subfloors ?
