JaonsS
Existing floor covering is 18mm T&G floorboards.
If you had to replace some floor joists, and to re level some floor joists, would you:
1. bin all the floorboards that have to get removed to fix the floor. replace the floorboards with 25mm wbp ply and tile directly onto that.
or
2. bin all the floorboards that have to get removed to fix the floor. replace the floorboards with 18mm wbp ply, then 6mm hardieboard, then tiles.
3. bin all the floorboards that have to get removed to fix the floor. replace the floorboards with 18mm chipboard floor, then 6mm hardieboard, then tiles.
4. put the original t&g floorboards back down, then 6mm hardieboard, then tiles.
i know all 3 options would work, but they all have their own cost and labour associated with them.
thanks
or
thanks
