L
loriwat
Hi , We clean a salon & day spa and they have slate flooring on the main traffic areas and in a pedicure room (in this room the finish looks real waxie I dont know if it is because the products they use in the pedi cure room are waxie & gritty but this room looks terrible) and also when they had the floor installed and a finish applied at that time (aprox. 2ys ago) they put an entry matt at the front door with a rubber backing which has ruined the floor finish at the entry. The rest of the traffic area"s are okay no problems except they didnt do a very good job applying the finish some places are done in Matt and some are either Semi-Gloss or Gloss..... We are going to redo the finish what I need to know is:
1. does it have to be stripped first?
2. anything special for the pedi-cure room?
3. what is the best finish for this enviorment?
Any info would be greatly appreciated.........
Thank you,
Lori
(Idaho Falls, Id)
Thank you,
Lori
(Idaho Falls, Id)
