Discuss Residential care home. in the Canada Tile Advice area at TilersForums.com.
slythetiler
Hi Folks,
I am about to start a kitchen splash back tiling job for a residential care home. I am torn between using epoxy grout and BAL with microban and then sealing the tiles.
I cant seem to find any stipulation for the use of epoxy grout in residential care homes.
So, my question is, would i be able to use a cementitious grout like BAL micromax that incorporates microban, along with a good quality grout sealer.
The kitchen is only used like a standard domestic kitchen. the building is two houses turned into one to create a care home.
Advise please folks.
Reply to Residential care home. in the Canada Tile Advice area at TilersForums.com
Hello I have a 10mx4m pool (depth average 1.5m) which is now drained due to construction work...
Hi all.I'm about to carry out a full bathroom refit which will incorporate a wet area.Im going...
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
benchwarmer
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
