Discuss Resin Backed Limestone - Failure in the Australia Tiling Forum area at TilersForums.com.
Deleted member 18697
We fitted a limestone floor a while ago, the tiles had a resin backing on them. We took advice from an adhesive company and they recommended their S1 adhesive. The floor has now extensively debonded. The adhesive has failed to bond to the backs of the tiles. Has anyone else had an experience like this? The base was a screed with under floor heating and we fitted ditra matting. The tiles were buttered before bedding. Any thoughts on this, gratefully received.
Spud
What have the adhesive company said? There are a few threads on here about failures with resin backed stone and I think you should contact the supplier and stone federation for some guidance as I believe the stone federation recommend that the resin is removed prior to fixing but since there are so many different types of products out there it can be a minefield
A lot of stone companies resin back their slabs to stop damage while being transported but recommend it removed prior to fixing , some use it to laminate the stone for structural strength and it can't be removed most of these types of products recommend fixing with s2 classified adhesives
The supplier knew about the under floor heating. I left 2 messages asking what their recommendation for fixing would be and got no reply! This in hindsight is quite telling. I therefore contacted the adhesive company who recommended their s1 adhesive (in writing). Their were no instructions from the supplier to remove the backing. This would have been a huge task as it was well stuck on and there was over 100m of stone. The adhesive company are due to come out and have a look and we will see how they play it.
jonnyc
The TTA put something out about this a while back may be worth contacting them in the meantime.
Can one just contact tta direct.this issue needs addressing for anyone who fixes limestone/marble with this resin backing.to me it seems that not all Resin backing is the same and potentially a real minefield for a fixer who is not a chemist by profession
jonnyc
I have never heard on any stone /marble supplier recommending that resin backingb should be removed prior to fixing
The D
Lol it's not a minefield for me I'm just a tiler ;0)
The TTA's view on this is that because there is no British Standard on the fixing of resin backed tiles it is down to the supplier to provide a fixing method. If they are unable to do this then the tiles are not fit for purpose.
The supplier did not provide a fixing method even when asked but the adhesive company did. Therefore, I believe I am covered from a legal point of view.
jonnyc
Dave did you send email to stone supplier and get any sort of reply or speak to them.
i forgot to ask when we spoke what name of stone was
Reply to Resin Backed Limestone - Failure in the Australia Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hi everyone I’m after a bit of advice. I’ve just removed the floor tiles in our on suite. After...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
