U
Unregistered
I needed to replace 3 tiles and in removing the old ones the backer board has got damaged - the tiles were on Marmox board so it damages fairly easily. I'm guessing there is no way to effectively repair the board so I think the way forward would be to remove the existing board that is exposed and damaged and replace that section of board. The tile are 300x600mm so the overall area of board is an L shape that would fit into a 600x600 square. The board is on a stud wall and if I cut out the old board the upright on the left side would only expose about 15mm of the wood to fit the board to. The board can have good support on the right side and from another upright in the centre of the board but such a small region at the edge doesn't seem ideal
