Discuss reveal above window in the British & UK Tiling Forum area at TilersForums.com.
Alan M
hi all.
im was preping a bathroom today . i was removing any loose skim etc and had to remove a piece of plasterboard that was stuck (bearly) to the lentel. the window is held on the sides but there is nothing holding it on the top. i will foam in around it to seal it up .
do you think i should stick some kind of board on again or could i tile onto the lentel and let the tile up against the window ( with 2mm gap siliconed )
thanks in advance
Reply to reveal above window in the British & UK Tiling Forum area at TilersForums.com
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
In short: would using some expanding foam behind 2 tiles that have a small amount of flex, where...
5K
I would very much appreciate the advice of anyone who has fitted Marmox boards as I have decided...
6K
Hi guys, sorry for long post, just after a bit of advice regarding my first proper complaint...
2 3
14K
Hi Fellas. I've (nearly) finished tiling my en-suite walls now and want to start on the window...
19K
reveal above window
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
