Rad2474
Been using my new wet cutter over the weekend,Homelux 900w. Anyway not to noisey solid guide rail with accurate numbering top and bottom. Used it today on porcelain floor tiles 10mm and handled them no problem with the standard blade although i imagine it'll manage even better with a marcrist/rubi blade.Couple of niggles,when you stop the wheel as it slows it tends to throw water out of the gap where the splash guard goes through the top plate so i'm going to bung that up with a dab of silicone also you have to tilt the water tray to get it out so it can get a bit messy unless your outside and just tip the water out first. For £69.99 not a bad piece of kit for a part time tiler like myself.
