rog
Discuss rog in the British & UK Tiling Forum area at TilersForums.com.
F
Fekin
Using UFH you need very flexible adhesive to allow the the rise and fall in temp.
Use a 2 part flexi adhesive, that's a powdered cement and a bottle of adative liquid that you mix in with the cement and water to give added flexability, then use a flexi grout.
All adhesive makers will do a 2 part flexi cement adhesive.
dock
Rog
If the substrate is cement:sand screed you could fix in Keraquick adhesive without using a liquid additive. The adhesive contains a significant level of additives enabling it to be used sucessfully in this type of application. The product conforms to EN 12002 and as such is categorized as an S1 adhesive thus defining its flexibility/deformability. Grout with Ultra Color Plus (26 colours) no additive needed.
The UFH should be commissioned before fixing by bringing the floor up to the intended working temperature and maintaining it for three days. Switch off the heating and leave 24 hours to cool prior to fixing.
Following completion of grouting and filling of movement joints leave for 28 days before switching on the UFH. Bring it up to working temperature at a maximum of 5 degrees C per day. This will minimise the initial stressess on the new installation.
hope it goes well
dock
grumpygrouter
I would say that you don't really need to go to the expense of a 2 part adhesive. BAL Rapid set flexy or Ardex X7R would be fine also. Flexy grout is a definate and I would also recommend skimming over the cables with levelling compound too. Makes tiling easier and gives protection to your cables from your trowel.
Reply to rog in the British & UK Tiling Forum area at TilersForums.com
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Just wondered what would be best? The original tiles had a few hairline cracks from the house...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hi there, we have just installed a Hetta UFH system.. they recommend a 6mm plywood over the top...
rog
Tags
usa
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
