Discuss Rotozip RZ3 spiral saw in the UK Tiling Forum area at TilersForums.com.
DHTiling
The RotoZip RZ3 Spiral Saw offers great cutting efficiency to save time, effort and money on the job. Tile cutting is performed easily by this RotoZip Spiral Saw. RotoZip. Makes difficult cuts easy.
The RZ3 kit is the entry level tool kit in the RotoZip product line. It contains the 500W RZ3 tool and an array of bits for dealing with the toughest cutting challenges.
Cutting other materials
The RotoZip® XBITS™ offer maximum cutting efficiency to save time, effort and money on the job.
The following range of materials can be cut with ease:
Wood
Laminate flooring, Softwood, Hardwood, Chipboard, OSB, Blockboard, Plywood
Metal
Sheet metal, Non-ferrous metal, Aluminium
Others
Drywall, Foam board, Cement board, Acrylic, Plastics, Fiberglass, Countertops
For more info click HERE.
And to purchase the Rotozip RZ3 click HERE.
surrey
well i will say its good for some jobs , but as far of drilling many holes in porcelain who are you trying to kidd , it will strip the diamonds off as it gets to hot as it runs so fast, have had 4 bits replaced , tried it for 5 months and have stopped using it , just use it for repairs and trimming , its good for ceramics and some floors but not alot. CTD are fed up of replacing bits and iam not the only one that has send this,
RotoZip
I am sorry to hear of your issues with the Diamond X-Bit. But you really should try our new X-Cores. The larger sizes (25mm, 30mm and 35mm) will do over 100 holes, DRY! and depending on the thickness of the tile, it takes about 10 seconds (Thicker tiles will take a few seconds more). If you dip the bit in a cup of water just to quench the diamond after evry hole or couple of holes, you will get at least 100 holes out of those sizes.
Reply to Rotozip RZ3 spiral saw in the UK Tiling Forum area at TilersForums.com
11K
Rizzle from the Portizzle
Screwfix Rotozip RZ5 starter kit. Never used but a bit of dust on the bag as been in the...
The Handy Manny
Well i took delivery of the new model rotozip RZ3 from Tradetiler.... First...
20K
TF Group Please Join
