Discuss rubi 45 degree trowels in the UK Tiling Forum area at TilersForums.com.
Gazzer
Different trowels. The raimondi give a good depth but you only get the full depth if you hold the blade of the trowel 90 degrees to the floor, So with a 10 m trowel and holding thetrowel as usual at about 45 degrees then you will get about 8 mm ( ish)
The Rubi system will give you full bed of the notch height as the notches are at 45 degrees to the trowel so combing adhesive as you normally do while holding the trowel at a comfortable 45 degree wil give the full bed.
Reply to rubi 45 degree trowels in the UK Tiling Forum area at TilersForums.com
Beginner Tiling Courses 1, 2, 3, 4 and 5 Day Tiling Courses? These are brilliant for a DIY...
